Setting up a new antenna for the first time is not really hard. But if in the past you used the TV Fool website to determine the best direction to aim your antenna, or which channels to expect, you will want to try using another website instead. The TV Fool website has not been updating its information so until this happens, here are some suitable alternative sites to use instead.[...] Read more @ mkvxstream.com
