In this episode of DIY or Buy we will be having a look at a Fire TV Stick and its problem that you can not really power them with a TVs USB Port. There is a product out there that solves this problem but I think you can build such a circuit better, simpler and cheaper the DIY way. So let's find out how the buy option works and how can we can create a DIY solution with Supercapacitors! Let's get started!
