This is another great resource for those looking for a media streamer that can do well with Kodi and other apps. It's a Google Spreadsheet that you can view here in more detail.
Anything rated Supberb or Best would do the best job when using it for Kodi. The Nvidia SHIELD remains at the top of the list for overall performance. But there are some close alternatives on the list that should do almost as well.
One thing to remember is an Android Media Streamer is still not on the same level as a Mini PC like an Intel NUC. Which you can find great NUC deals on eBay right now.
A mini PC with a stripped-down version of Windows that automatically boots into Kodi will blow away any Android box except for this one. When you install Kodi, it will blow any Android Box away listed above and provide you with the ultimate picture and audio quality.
