Find Hidden Categories on Netflix With Codes
Post by Admin » Wed Jul 31, 2024 6:49 pm
You probably know that Netflix is using a really strange system to categorize its films and TV shows. Indeed, there isn't any categories tab... We have the solution, with this site, you will be able to find categories by a little code.
Once you've found the code for the category that you're searching, you just have to put the code in the search bar or you can replace the xx in this link. https://netflix.com/browse/genre/xx
➤➤➤ SEE THE CODES
Tech Marvels, Streaming Hacks, and More! Check out ChitChat our sister site with a lighter, brighter theme! 🚀 #TechTalks
