How to Clear Cache on Roku to Fix Broken Channels
Post by Admin » Mon Jun 08, 2020 7:34 pm
Here's a quick and easy way to clear the Roku Cache
This is a good thing to do if you have issues with slow performance or channels not loading correctly. It only takes a few seconds so be sure and give it a try next time something is amiss.
Before you begin, make sure the “Home” screen is selected from the main menu.
Then while on the Home Screen from your Roku Remote:
Press Home 5X > Up 1X > Rewind 2X > Fast Forward 2X > After Auto Reboot = Roku Cache is Cleared
Once done, visit this page to add some popular Roku channels!
