Roku Channels That Rock!
BenjaminLinus
Contact:
Post by BenjaminLinus » Sat Jul 06, 2019 3:09 pm
No doubt about it, Roku makes a great media streamer! It's easy for anyone to use. And most of the time it works pretty much without any hiccups.
But if you are first time Roku user it can be a little tough to try and figure out which Roku channels to add first.
Slogging through thousands of channels in their channel store with many that all have the same old play it again public domain shows can be a bit of a pain.
Here is a great table of Roku channels that will take out some of the guess work. Because these are all pretty awesome Roku Channels that will Rock your Roku media streamer.
Access the full Best Roku Channels That Rock list here
Add the Roku channels directly to your Roku from the list. And Once the channels have been added go to Settings/System and check for update.
All the new channels will then show up at the bottom of your channels list.
